Introdução
This guide outlines how to remove the fan of an HP Chromebook x360 14c-ca0053. The fan functions to prevent the device from overheating, but it is fragile and susceptible to damage. If the device is overheating or making a whining sound, the fan likely needs to be replaced.
O que você precisa
Use tweezers to apply light pressure on the outer sides of the 2 small screw covers located near the bottom of the device.
Rotate the covers until they pop up out of the screw socket enough to remove them with tweezers.
Open the tweezers wide enough to fit on each side of motherboard battery connection.
Pull the connector directly out of its socket.
Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the heatsink.
Use a Phillips #0 screwdriver to remove the three 3 mm screws that secure the fan.
