Ir para o conteúdo principal
HP Chromebook x360 14c-ca0053 Fan Replacement
O que você precisa
  1. HP Chromebook x360 14c-ca0053 Fan Replacement, Lower Case: passo 1, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement, Lower Case: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to apply light pressure on the outer sides of the 2 small screw covers located near the bottom of the device.
    • Rotate the covers until they pop up out of the screw socket enough to remove them with tweezers.
  2. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 2, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 3.5 mm screws.
  3. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 3, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement: passo 3, imagem 2 %32 HP Chromebook x360 14c-ca0053 Fan Replacement: passo 3, imagem 3 %32
    • Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
  4. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 4, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
  5. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 5, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement: passo 5, imagem 2 %32 HP Chromebook x360 14c-ca0053 Fan Replacement: passo 5, imagem 3 %32
    • Insert an opening pick between lower case and chassis.
    • Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
  6. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 6, imagem 1 %32
    • Lift the lower case up and off.
  7. HP Chromebook x360 14c-ca0053 Fan Replacement, Battery: passo 7, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement, Battery: passo 7, imagem 2 %32 HP Chromebook x360 14c-ca0053 Fan Replacement, Battery: passo 7, imagem 3 %32
    Comprar
    • Open the tweezers wide enough to fit on each side of motherboard battery connection.
    • Pull the connector directly out of its socket.
  8. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 8, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement: passo 8, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the five 3 mm screws that secure the battery.
    • These screws are labeled 1-5.
  9. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 9, imagem 1 %32
    • Lift the battery up and out.
    • Be careful as to not puncture or damage the battery.
  10. HP Chromebook x360 14c-ca0053 Fan Replacement, Heat Sink: passo 10, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement, Heat Sink: passo 10, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the heatsink.
  11. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 11, imagem 1 %32
    • Remove the heat sink.
    • Add thermal paste to the new heat sink before replacement.
  12. HP Chromebook x360 14c-ca0053 Fan Replacement, Fan: passo 12, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement, Fan: passo 12, imagem 2 %32 HP Chromebook x360 14c-ca0053 Fan Replacement, Fan: passo 12, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws that secure the fan.
  13. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 13, imagem 1 %32 HP Chromebook x360 14c-ca0053 Fan Replacement: passo 13, imagem 2 %32 HP Chromebook x360 14c-ca0053 Fan Replacement: passo 13, imagem 3 %32
    Comprar
    • Place the tweezers gently underneath the fan's motherboard connection and lift up to disconnect it.
  14. HP Chromebook x360 14c-ca0053 Fan Replacement: passo 14, imagem 1 %32
    • Lift the fan up and out of the chassis.
Conclusão
Cassidy
Membro desde: 09/18/23
691 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 77
