Ir para o conteúdo principal
HP Chromebook x360 14-da0011dx Lower Case Replacement
O que você precisa
  1. HP Chromebook x360 14-da0011dx Lower Case Replacement, Lower Case: passo 1, imagem 1 %32
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. HP Chromebook x360 14-da0011dx Lower Case Replacement: passo 2, imagem 1 %32 HP Chromebook x360 14-da0011dx Lower Case Replacement: passo 2, imagem 2 %32
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. HP Chromebook x360 14-da0011dx Lower Case Replacement: passo 3, imagem 1 %32 HP Chromebook x360 14-da0011dx Lower Case Replacement: passo 3, imagem 2 %32 HP Chromebook x360 14-da0011dx Lower Case Replacement: passo 3, imagem 3 %32
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Where to get replacement parts for this one?
Aguinaldo Motta - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 69
Duração total: 391
