Ir para o conteúdo principal
HP Chromebook x360 14-da0011dx I/O Board Replacement
O que você precisa
  1. HP Chromebook x360 14-da0011dx I/O Board Replacement, Lower Case: passo 1, imagem 1 %32
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 2, imagem 1 %32 HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 2, imagem 2 %32
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 3, imagem 1 %32 HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 3, imagem 2 %32 HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 3, imagem 3 %32
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. HP Chromebook x360 14-da0011dx I/O Board Replacement, Battery: passo 4, imagem 1 %32 HP Chromebook x360 14-da0011dx I/O Board Replacement, Battery: passo 4, imagem 2 %32
    • Remove the cable attached to the battery.
  5. HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 5, imagem 1 %32 HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 5, imagem 2 %32
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 6, imagem 1 %32
    • Lift the battery out of the chassis.
  7. HP Chromebook x360 14-da0011dx I/O Board Replacement, I/O Board: passo 7, imagem 1 %32 HP Chromebook x360 14-da0011dx I/O Board Replacement, I/O Board: passo 7, imagem 2 %32 HP Chromebook x360 14-da0011dx I/O Board Replacement, I/O Board: passo 7, imagem 3 %32
    • Locate the I/O Board on the top left of the laptop.
    • Remove the four 3.0 mm screws with the Phillips #1 screwdriver.
  8. HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 8, imagem 1 %32 HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 8, imagem 2 %32
    • Flip up the ZIF connector locking flaps connected to the I/O board.
    • Remove the ribbon cables.
  9. HP Chromebook x360 14-da0011dx I/O Board Replacement: passo 9, imagem 1 %32
    • Lift the I/O board up and out.
Conclusão
Jared Tallent
Membro desde: 02/14/23
196 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 214
