Introdução
This guide will allow the user to replace the battery in the HP Chromebook x360 14-da0011dx. If the laptop only powers on when the adapter is plugged in, the battery may be faulty. Before beginning, make sure you power off your device and remove any external power sources. Be aware of a swollen battery, as it could potentially catch fire. If the battery is hot or has a smell, it could potentially be swollen. Handle with caution.
O que você precisa
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Uma outra pessoa concluiu este guia.
