Ir para o conteúdo principal
HP Chromebook CB2L Keyboard Replacement
O que você precisa
  1. HP Chromebook CB2L Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Flip the Chromebook over so the blue panels are showing.
    • Starting in the top left or right corner, use the plastic opening tool to remove the large blue panel.
    • This piece has fragile plastic connectors. Don't damage them.
  2. HP Chromebook CB2L Keyboard Replacement: passo 2, imagem 1 %32 HP Chromebook CB2L Keyboard Replacement: passo 2, imagem 2 %32
    • Remove six 4.77mm screws using the Phillips #1 screwdriver.
  3. HP Chromebook CB2L Keyboard Replacement: passo 3, imagem 1 %32 HP Chromebook CB2L Keyboard Replacement: passo 3, imagem 2 %32 HP Chromebook CB2L Keyboard Replacement: passo 3, imagem 3 %32
    • Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
  4. HP Chromebook CB2L Keyboard Replacement: passo 4, imagem 1 %32 HP Chromebook CB2L Keyboard Replacement: passo 4, imagem 2 %32
    • Remove twenty 3.42mm screws with the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Keyboard Replacement: passo 5, imagem 1 %32 HP Chromebook CB2L Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the black and white antennae wires, the white ribbon cables, the large black connecter, and the speaker cable from the motherboard.
    • Grabbing the boards by the edges, remove the motherboard and audio/USB board.
  6. HP Chromebook CB2L Keyboard Replacement: passo 6, imagem 1 %32 HP Chromebook CB2L Keyboard Replacement: passo 6, imagem 2 %32 HP Chromebook CB2L Keyboard Replacement: passo 6, imagem 3 %32
    • Remove the red and blue antennae wires from the SIM card board.
    • Remove the SIM card tray.
    • Flip the board over and use the plastic opening tool to remove the ribbon cable, then remove the board.
  7. HP Chromebook CB2L Keyboard Replacement: passo 7, imagem 1 %32 HP Chromebook CB2L Keyboard Replacement: passo 7, imagem 2 %32
    • Remove the speakers and battery.
  8. HP Chromebook CB2L Keyboard Replacement: passo 8, imagem 1 %32 HP Chromebook CB2L Keyboard Replacement: passo 8, imagem 2 %32
    • Remove eighteen 2.5mm screws using the Phillips #1 screwdriver.
    • Flip the Chromebook so the top is on the table and the push out the keyboard from the back.
Conclusão
Nathan Petrie
Membro desde: 10/31/18
277 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G4, Harley Fall 2018 Membro de IUPUI, Team S1-G4, Harley Fall 2018
IUPUI-HARLEY-F18S1G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 186
