Ir para o conteúdo principal
HP Chromebook 14-x015wm Battery Replacement
O que você precisa
  1. HP Chromebook 14-x015wm Battery Replacement, Battery: passo 1, imagem 1 %32 HP Chromebook 14-x015wm Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the Chromebook upside down so that the bottom is facing upwards.
    • Remove the small rubber circles from all four corners.
    • Remove the other three rubber pads from the bottom
    • Proceed to unscrew all the screws.
    • Keep the screws on a magnetic mat or in a secure location and keep track of which screws went where.
  2. HP Chromebook 14-x015wm Battery Replacement: passo 2, imagem 1 %32
    • Flip the laptop back over and open it so that the keyboard is revealed to you.
    • Use a plastic opening tool to pry off the keyboard. It's slightly difficult to get off, but go evenly around all four sides until it pops out.
    • Be careful of the ribbons underneath that connect the keyboard to the internal components.
  3. HP Chromebook 14-x015wm Battery Replacement: passo 3, imagem 1 %32 HP Chromebook 14-x015wm Battery Replacement: passo 3, imagem 2 %32
    • The long, flat, black component that takes up the majority of the space is the battery.
    • All you are required to do is unscrew the screws attached to the battery and then gently remove the battery from the Chromebook.
    • Make sure to keep track of where the screws came from.
Conclusão
Cameron Sinclaire
Membro desde: 10/27/17
201 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 41
Duração total: 1,452
