Ir para o conteúdo principal
HP Chromebook 14-x013dx Speakers Replacement
O que você precisa
  1. HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: passo 1, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: passo 1, imagem 2 %32
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Speakers Replacement: passo 2, imagem 1 %32
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Speakers Replacement: passo 3, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement: passo 3, imagem 2 %32
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Speakers Replacement: passo 4, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement: passo 4, imagem 2 %32
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Speakers Replacement: passo 5, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement: passo 5, imagem 2 %32 HP Chromebook 14-x013dx Speakers Replacement: passo 5, imagem 3 %32
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Speakers Replacement, Battery: passo 6, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement, Battery: passo 6, imagem 2 %32
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook 14-x013dx Speakers Replacement: passo 7, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement: passo 7, imagem 2 %32
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook 14-x013dx Speakers Replacement: passo 8, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement: passo 8, imagem 2 %32
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook 14-x013dx Speakers Replacement: passo 9, imagem 1 %32
    • Lift the battery out of the laptop case.
  10. HP Chromebook 14-x013dx Speakers Replacement, Speakers: passo 10, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement, Speakers: passo 10, imagem 2 %32
    • Unplug Speaker from motherboard.
  11. HP Chromebook 14-x013dx Speakers Replacement: passo 11, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement: passo 11, imagem 2 %32
    • Pull the left and right speaker out carefully.
    • The corners of the the speakers will be held in place by tape, and may require a bit of force.
  12. HP Chromebook 14-x013dx Speakers Replacement: passo 12, imagem 1 %32 HP Chromebook 14-x013dx Speakers Replacement: passo 12, imagem 2 %32
    • Remove the black tape holding the wire to the laptop casing.
    • Remove the wires from the three hooks on the case.
Conclusão
Uma outra pessoa concluiu este guia.
NHerbert
Membro desde: 09/28/17
602 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G6, Nance Fall 2017 Membro de USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 258
