Ir para o conteúdo principal
HP Chromebook 14-x013dx Screen Replacement
O que você precisa
  1. HP Chromebook 14-x013dx Screen Replacement, Screen: passo 1, imagem 1 %32 HP Chromebook 14-x013dx Screen Replacement, Screen: passo 1, imagem 2 %32 HP Chromebook 14-x013dx Screen Replacement, Screen: passo 1, imagem 3 %32
    • Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
    • The nylon strips on the side may be difficult to remove, as they are held on with adhesive. A spudger can be used to help remove these strips before removing with fingers.
    • Remove the two 2mm screws holding the bezel to the laptop case.
  2. HP Chromebook 14-x013dx Screen Replacement: passo 2, imagem 1 %32 HP Chromebook 14-x013dx Screen Replacement: passo 2, imagem 2 %32
    • Gently pry around the edges of the display using a spudger to remove the bezel that borders the screen.
  3. HP Chromebook 14-x013dx Screen Replacement: passo 3, imagem 1 %32 HP Chromebook 14-x013dx Screen Replacement: passo 3, imagem 2 %32
    • Remove glued plastic at the bottom of the cover.
  4. HP Chromebook 14-x013dx Screen Replacement: passo 4, imagem 1 %32
    • Once glue is separated, pop out the front cover by pulling upwards on the hinge.
  5. HP Chromebook 14-x013dx Screen Replacement: passo 5, imagem 1 %32 HP Chromebook 14-x013dx Screen Replacement: passo 5, imagem 2 %32
    • Once the bezel has been removed, remove the four 5mm screws at the corners of the screen using a PH00 screwdriver.
  6. HP Chromebook 14-x013dx Screen Replacement: passo 6, imagem 1 %32 HP Chromebook 14-x013dx Screen Replacement: passo 6, imagem 2 %32 HP Chromebook 14-x013dx Screen Replacement: passo 6, imagem 3 %32
    • Before completely removing the screen, detach the connected located at the bottom of the screen.
    • The connection to be removed should have a barcode marking.
Conclusão
3 outras pessoas executaram este guia.
NHerbert
Membro desde: 09/28/17
602 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G6, Nance Fall 2017 Membro de USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,794
