Ir para o conteúdo principal
HP Chromebook 14-x013dx Keyboard/Touchpad Replacement
O que você precisa
  1. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement, Keyboard, Touchpad: passo 1, imagem 1 %32 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement, Keyboard, Touchpad: passo 1, imagem 2 %32
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: passo 2, imagem 1 %32
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: passo 3, imagem 1 %32 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: passo 3, imagem 2 %32
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: passo 4, imagem 1 %32 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: passo 4, imagem 2 %32
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: passo 5, imagem 1 %32 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: passo 5, imagem 2 %32 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: passo 5, imagem 3 %32
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
Conclusão
4 outras pessoas executaram este guia.
NHerbert
Membro desde: 09/28/17
602 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G6, Nance Fall 2017 Membro de USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 1,275
