Ir para o conteúdo principal
HP Chromebook 14-x013dx Camera Replacement
O que você precisa
  1. HP Chromebook 14-x013dx Camera Replacement, Keyboard, Touchpad: passo 1, imagem 1 %32 HP Chromebook 14-x013dx Camera Replacement, Keyboard, Touchpad: passo 1, imagem 2 %32
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Camera Replacement: passo 2, imagem 1 %32
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Camera Replacement: passo 3, imagem 1 %32 HP Chromebook 14-x013dx Camera Replacement: passo 3, imagem 2 %32
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Camera Replacement: passo 4, imagem 1 %32 HP Chromebook 14-x013dx Camera Replacement: passo 4, imagem 2 %32
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Camera Replacement: passo 5, imagem 1 %32 HP Chromebook 14-x013dx Camera Replacement: passo 5, imagem 2 %32 HP Chromebook 14-x013dx Camera Replacement: passo 5, imagem 3 %32
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Camera Replacement, Camera: passo 6, imagem 1 %32 HP Chromebook 14-x013dx Camera Replacement, Camera: passo 6, imagem 2 %32
    • Disconnect the black and white wires connected to the Wi-Fi module.
    • Remove the wire from the casing.
  7. HP Chromebook 14-x013dx Camera Replacement: passo 7, imagem 1 %32
    • Pull the ribbon cable out of socket.
  8. HP Chromebook 14-x013dx Camera Replacement: passo 8, imagem 1 %32 HP Chromebook 14-x013dx Camera Replacement: passo 8, imagem 2 %32 HP Chromebook 14-x013dx Camera Replacement: passo 8, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the two 6mm screws located at the upper left and right corners.
  9. HP Chromebook 14-x013dx Camera Replacement: passo 9, imagem 1 %32 HP Chromebook 14-x013dx Camera Replacement: passo 9, imagem 2 %32
    • Remove the lid out of the laptop.
    • It is helpful to rotate the lid to a 90-degree angle.
  10. HP Chromebook 14-x013dx Camera Replacement: passo 10, imagem 1 %32
    • Using the plastic opening tool, pry the left and right side of the top of the lid.
    • It is not necessary to remove the entire frame, only pry the top to expose the camera.
  11. HP Chromebook 14-x013dx Camera Replacement: passo 11, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, gently remove the connection hold the camera in place.
  12. HP Chromebook 14-x013dx Camera Replacement: passo 12, imagem 1 %32 HP Chromebook 14-x013dx Camera Replacement: passo 12, imagem 2 %32
    • Gently pry the camera mount out of the lid.
    • Lift the camera mount out of the lid.
Conclusão
Uma outra pessoa concluiu este guia.
Eile Woeltje
Membro desde: 11/06/19
304 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G3, Stella Fall 2019 Membro de IUPUI, Team S1-G3, Stella Fall 2019
IUPUI-STELLA-F19S1G3
Membros da 3
Autoria de 2 guias
Um comentário
Thank you, very helpful. You could also just start at Step 10 without removing the display
Douglas Walker - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 776
