Ir para o conteúdo principal
HP Chromebook 14-x010wm Charging Port Replacement
O que você precisa
  1. HP Chromebook 14-x010wm Charging Port Replacement, Battery: passo 1, imagem 1 %32 HP Chromebook 14-x010wm Charging Port Replacement, Battery: passo 1, imagem 2 %32 HP Chromebook 14-x010wm Charging Port Replacement, Battery: passo 1, imagem 3 %32
    • Remove the thirteen 5.7mm screws from the back of the laptop using a Phillips #00 screwdriver.
    • Remove rubber covers to reveal concealed screws, as needed.
  2. HP Chromebook 14-x010wm Charging Port Replacement: passo 2, imagem 1 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 2, imagem 2 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 2, imagem 3 %32
    • Flip the laptop over carefully and open the cover.
    • Use a plastic opening tool to pry open the front edge and along the sides of the keyboard cover to separate it from the computer’s base.
    • Lift the keyboard cover from the computer’s base carefully.
  3. HP Chromebook 14-x010wm Charging Port Replacement: passo 3, imagem 1 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 3, imagem 2 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 3, imagem 3 %32
    • Lifting the keyboard cover too much may damage the internal cables of the laptop.
    • Lift the black plastic flap, using a plastic opening tool, of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
    • Disconnect the keyboard cable by slowly pulling it from the system board.
    • Lift the black plastic flap that holds the battery cable in place using a plastic opening tool.
    • Remove the battery cable by slowly pulling the plastic connector towards you.
    • Remove carefully and set aside keyboard panel.
  4. HP Chromebook 14-x010wm Charging Port Replacement: passo 4, imagem 1 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 4, imagem 2 %32
    • Flip the plastic flap holding the battery cable using a plastic opening tool.
    • Disconnect the battery cable by carefully pulling it from the system board.
  5. HP Chromebook 14-x010wm Charging Port Replacement: passo 5, imagem 1 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 5, imagem 2 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 5, imagem 3 %32
    • Remove the seven M2xL3.0 screws from around the battery using a Phillips #00 screwdriver.
  6. HP Chromebook 14-x010wm Charging Port Replacement: passo 6, imagem 1 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 6, imagem 2 %32
    • Peel the wire band off of the battery carefully.
    • Remove the battery by lifting slightly, then slowly pull it towards you.
  7. HP Chromebook 14-x010wm Charging Port Replacement, Charging Port: passo 7, imagem 1 %32 HP Chromebook 14-x010wm Charging Port Replacement, Charging Port: passo 7, imagem 2 %32 HP Chromebook 14-x010wm Charging Port Replacement, Charging Port: passo 7, imagem 3 %32
    • Use a plastic opening tool to undo the tabs securing the charging port.
    • Then gently lift the port up and away from the laptop edge.
  8. HP Chromebook 14-x010wm Charging Port Replacement: passo 8, imagem 1 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 8, imagem 2 %32 HP Chromebook 14-x010wm Charging Port Replacement: passo 8, imagem 3 %32
    • Use a plastic opening tool to pry both ends of the corresponding white plug from it's port at the motherboard.
    • Carefully pull the plug out of the port.
Conclusão
Equipe
IUPUI, Team S3-G3, Harley Spring 2019 Membro de IUPUI, Team S3-G3, Harley Spring 2019
IUPUI-HARLEY-S19S3G3
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,051
