Ir para o conteúdo principal
HP Chromebook 14-q063cl Battery Replacement
O que você precisa
  1. HP Chromebook 14-q063cl Battery Replacement, Battery: passo 1, imagem 1 %32 HP Chromebook 14-q063cl Battery Replacement, Battery: passo 1, imagem 2 %32 HP Chromebook 14-q063cl Battery Replacement, Battery: passo 1, imagem 3 %32
    • Flip the laptop upside down so that the bottom is facing upwards.
    • Use Phillips #0 screwdriver to remove nine 6.7 mm screws from the bottom panel.
  2. HP Chromebook 14-q063cl Battery Replacement: passo 2, imagem 1 %32 HP Chromebook 14-q063cl Battery Replacement: passo 2, imagem 2 %32 HP Chromebook 14-q063cl Battery Replacement: passo 2, imagem 3 %32
    • Use a metal spudger to pry the plastic covers off four additional screws.
  3. HP Chromebook 14-q063cl Battery Replacement: passo 3, imagem 1 %32 HP Chromebook 14-q063cl Battery Replacement: passo 3, imagem 2 %32 HP Chromebook 14-q063cl Battery Replacement: passo 3, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the four remaining 6.7 mm screws from the bottom panel.
  4. HP Chromebook 14-q063cl Battery Replacement: passo 4, imagem 1 %32 HP Chromebook 14-q063cl Battery Replacement: passo 4, imagem 2 %32 HP Chromebook 14-q063cl Battery Replacement: passo 4, imagem 3 %32
    • Turn the laptop upright. Open it so the screen is visible.
    • Use an opening tool or picks to undo the clips around the perimeter of the keyboard assembly and separate it from the rest of the laptop
    • Disconnect the ribbon cables attaching the keyboard to the motherboard.
    • Use caution when performing this step so as to not break the keyboard assembly or rip any cables or connectors connected to the board. Don't yank the keyboard assembly from the device.
  5. HP Chromebook 14-q063cl Battery Replacement: passo 5, imagem 1 %32 HP Chromebook 14-q063cl Battery Replacement: passo 5, imagem 2 %32 HP Chromebook 14-q063cl Battery Replacement: passo 5, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove three 4.6 mm screws securing the battery to the case.
  6. HP Chromebook 14-q063cl Battery Replacement: passo 6, imagem 1 %32 HP Chromebook 14-q063cl Battery Replacement: passo 6, imagem 2 %32 HP Chromebook 14-q063cl Battery Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the speakers and move them to the side, making sure the wires are not disturbed.
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out.
    • Use tweezers to unplug the bundled cable connector from the motherboard.
    • Remove the battery from the laptop.
    • Carefully handle the battery while removing from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 135
