Ir para o conteúdo principal
HP Chromebook 14-q010nr Touchpad Replacement
O que você precisa
  1. HP Chromebook 14-q010nr Touchpad Replacement, Keyboard: passo 1, imagem 1 %32 HP Chromebook 14-q010nr Touchpad Replacement, Keyboard: passo 1, imagem 2 %32 HP Chromebook 14-q010nr Touchpad Replacement, Keyboard: passo 1, imagem 3 %32
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Use an opening pick to separate the keyboard from the chassis.
    • Lift the keyboard away, with care not to damage the connected ribbon cables.
  2. HP Chromebook 14-q010nr Touchpad Replacement: passo 2, imagem 1 %32 HP Chromebook 14-q010nr Touchpad Replacement: passo 2, imagem 2 %32
    • Flip up the black lock bars on the ZIF connectors, then remove the ribbon cables.
  3. HP Chromebook 14-q010nr Touchpad Replacement: passo 3, imagem 1 %32
    • Gently raise the keyboard from the device and separate the two components.
  4. HP Chromebook 14-q010nr Touchpad Replacement, Touchpad: passo 4, imagem 1 %32 HP Chromebook 14-q010nr Touchpad Replacement, Touchpad: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Unscrew the two screws securing the touchpad to the keyboard with a Phillips #00 screwdriver.
    • The touchpad may fall out of its position after removing the screws, so carefully remove it with tweezers.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 67
