Ir para o conteúdo principal
HP Chromebook 14-q010nr Motherboard Replacement
O que você precisa
  1. HP Chromebook 14-q010nr Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Begin by turning the Chromebook onto its back.
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Four screws will be located underneath the device's rubber foot pads.
  2. HP Chromebook 14-q010nr Motherboard Replacement: passo 2, imagem 1 %32 HP Chromebook 14-q010nr Motherboard Replacement: passo 2, imagem 2 %32 HP Chromebook 14-q010nr Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the keyboard from the base plate with an opening pick to pry it open from both sides of the keyboard.
    • Beginning from the corners closest to the computer screen may result in easier disconnection.
  3. HP Chromebook 14-q010nr Motherboard Replacement: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the seven screws securing the battery.
  4. HP Chromebook 14-q010nr Motherboard Replacement: passo 4, imagem 1 %32
    • Gently disconnect the battery's motherboard connection by pinching the white attachment and pulling the plug directly out of the port.
  5. HP Chromebook 14-q010nr Motherboard Replacement: passo 5, imagem 1 %32 HP Chromebook 14-q010nr Motherboard Replacement: passo 5, imagem 2 %32
    • Before removing the battery, gently lift the white ribbon cable taped to the battery.
    • Gently pull up from the back of the battery to remove it.
  6. HP Chromebook 14-q010nr Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Remove the eleven motherboard screws with a 2mm Phillips screwdriver.
  7. HP Chromebook 14-q010nr Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the white ribbon cable from the motherboard by lifting the black ZIF connector.
  8. HP Chromebook 14-q010nr Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the five screws attached to the connector plate.
    • Remove the monitor connector by lifting it gently upward.
  9. HP Chromebook 14-q010nr Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the antenna cables on the right side of the motherboard.
    • Carefully lift the motherboard up to remove it. Use a spudger for ease.
Conclusão
Julian Knight
Membro desde: 09/22/22
159 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 171
