Ir para o conteúdo principal
HP Chromebook 14-q010nr Battery Replacement
O que você precisa
  1. HP Chromebook 14-q010nr Battery Replacement, Battery: passo 1, imagem 1 %32
    • Begin by turning the Chromebook onto its back.
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Four screws will be located underneath the device's rubber foot pads.
  2. HP Chromebook 14-q010nr Battery Replacement: passo 2, imagem 1 %32 HP Chromebook 14-q010nr Battery Replacement: passo 2, imagem 2 %32 HP Chromebook 14-q010nr Battery Replacement: passo 2, imagem 3 %32
    • Remove the keyboard from the base plate with an opening pick to pry it open from both sides of the keyboard.
    • Beginning from the corners closest to the computer screen may result in easier disconnection.
  3. HP Chromebook 14-q010nr Battery Replacement: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the seven screws securing the battery.
  4. HP Chromebook 14-q010nr Battery Replacement: passo 4, imagem 1 %32
    • Gently disconnect the battery's motherboard connection by pinching the white attachment and pulling the plug directly out of the port.
  5. HP Chromebook 14-q010nr Battery Replacement: passo 5, imagem 1 %32 HP Chromebook 14-q010nr Battery Replacement: passo 5, imagem 2 %32
    • Before removing the battery, gently lift the white ribbon cable taped to the battery.
    • Gently pull up from the back of the battery to remove it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 140
