Ir para o conteúdo principal
HP Chromebook 14-ca061dx Motherboard Replacement
O que você precisa
  1. HP Chromebook 14-ca061dx Motherboard Replacement, Keyboard: passo 1, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement, Keyboard: passo 1, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement, Keyboard: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    $3.99
    Comprar
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. HP Chromebook 14-ca061dx Motherboard Replacement: passo 2, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 2, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. HP Chromebook 14-ca061dx Motherboard Replacement: passo 3, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. HP Chromebook 14-ca061dx Motherboard Replacement: passo 4, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the two 9mm Phillips #1 screws.
  5. HP Chromebook 14-ca061dx Motherboard Replacement: passo 5, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 5, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 5, imagem 3 %32
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  6. HP Chromebook 14-ca061dx Motherboard Replacement: passo 6, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 6, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 6, imagem 3 %32
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  7. HP Chromebook 14-ca061dx Motherboard Replacement: passo 7, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 7, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 7, imagem 3 %32
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  8. HP Chromebook 14-ca061dx Motherboard Replacement: passo 8, imagem 1 %32
    • Lift the rest of the keyboard up from the base of the Chromebook.
  9. HP Chromebook 14-ca061dx Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement, Motherboard: passo 9, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement, Motherboard: passo 9, imagem 3 %32
    Comprar
    • Peel back the black electrical tape from the wires connecting the battery to the motherboard using tweezers.
    • Pull the white plastic piece toward you using your finger to disconnect the wires.
    • Make sure to pull the plastic and not the wires, because pulling the wires could cause them to break.
  10. HP Chromebook 14-ca061dx Motherboard Replacement: passo 10, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 10, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 10, imagem 3 %32
    • Peel back the plastic covering on the wires connecting the speaker to the motherboard.
    • Using your finger, pull the white plastic piece toward you and remove.
    • Make sure to avoid pulling the wires, for it may cause them to break.
  11. HP Chromebook 14-ca061dx Motherboard Replacement: passo 11, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 11, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 11, imagem 3 %32
    • Pull back the plastic covering of the cables connecting the motherboard to the daughter-board using tweezers.
    • Flip up both of the black plastic pieces using the spudger.
    • Remove both of the blue and white cables by pulling the blue plastic pieces toward you.
    • Disconnect the cables carefully because they are fragile.
  12. HP Chromebook 14-ca061dx Motherboard Replacement: passo 12, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 12, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 12, imagem 3 %32
    • Peel back the plastic covering of the WiFi card using tweezers.
    • With a JIS J000 head, remove the 2mm screw.
    • Pull the WiFi card toward the left to remove.
  13. HP Chromebook 14-ca061dx Motherboard Replacement: passo 13, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 13, imagem 2 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 13, imagem 3 %32
    • Peel back the plastic covering on the wires connecting the screen to the motherboard using tweezers.
    • Peel back the black electrical tape using tweezers.
    • Remove the wires by pulling the plastic piece away from you.
    • Make sure to pull the plastic piece and not the wires because the wires are fragile.
  14. HP Chromebook 14-ca061dx Motherboard Replacement: passo 14, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 14, imagem 2 %32
    • Using a PH0 head, remove the two 4 mm screws from the metal piece.
    • Remove the metal piece using tweezers.
  15. HP Chromebook 14-ca061dx Motherboard Replacement: passo 15, imagem 1 %32 HP Chromebook 14-ca061dx Motherboard Replacement: passo 15, imagem 2 %32
    • Remove the four, 4 mm screws from the motherboard using a PH0 head.
    • Remove the motherboard from the Chromebook.
Conclusão
Jean Arevalo
Membro desde: 10/31/19
778 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Membro de UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 909
