Ir para o conteúdo principal
HP Chromebook 14-ca061dx Keyboard Replacement
O que você precisa
  1. HP Chromebook 14-ca061dx Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 HP Chromebook 14-ca061dx Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 HP Chromebook 14-ca061dx Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    $3.99
    Comprar
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. HP Chromebook 14-ca061dx Keyboard Replacement: passo 2, imagem 1 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 2, imagem 2 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 2, imagem 3 %32
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. HP Chromebook 14-ca061dx Keyboard Replacement: passo 3, imagem 1 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 3, imagem 2 %32
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. HP Chromebook 14-ca061dx Keyboard Replacement: passo 4, imagem 1 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 4, imagem 2 %32
    • Remove the two 9mm Phillips #1 screws.
  5. HP Chromebook 14-ca061dx Keyboard Replacement: passo 5, imagem 1 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 5, imagem 2 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 5, imagem 3 %32
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  6. HP Chromebook 14-ca061dx Keyboard Replacement: passo 6, imagem 1 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 6, imagem 2 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 6, imagem 3 %32
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  7. HP Chromebook 14-ca061dx Keyboard Replacement: passo 7, imagem 1 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 7, imagem 2 %32 HP Chromebook 14-ca061dx Keyboard Replacement: passo 7, imagem 3 %32
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  8. HP Chromebook 14-ca061dx Keyboard Replacement: passo 8, imagem 1 %32
    • Lift the rest of the keyboard up from the base of the Chromebook.
Conclusão
Jean Arevalo
Membro desde: 10/31/19
778 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Membro de UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
Membros da 3
Autoria de 6 guias
Um comentário
good afternoon, excuse me, I have a question, I also have the same brand HP Chromebook 14-ca061dx and I just want to know where the anti-write screw is, I want to remove the anti-write screw to install windows 10..
Marcos Perea - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,391
