Ir para o conteúdo principal
HP Chromebook 14-ca061dx Display Replacement
O que você precisa
  1. HP Chromebook 14-ca061dx Display Replacement, Display: passo 1, imagem 1 %32 HP Chromebook 14-ca061dx Display Replacement, Display: passo 1, imagem 2 %32 HP Chromebook 14-ca061dx Display Replacement, Display: passo 1, imagem 3 %32
    • Flip the Chromebook so that the underside is facing upwards.
    • Follow along the edge with the iFixit opening tool to unhinge the display frame.
  2. HP Chromebook 14-ca061dx Display Replacement: passo 2, imagem 1 %32
    • Flip the Chromebook right side up and open it to form a 180 degree angle.
  3. HP Chromebook 14-ca061dx Display Replacement: passo 3, imagem 1 %32
    • Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
    • The bottom edge of the bezel may stick because there is glue holding it together.
  4. HP Chromebook 14-ca061dx Display Replacement: passo 4, imagem 1 %32 HP Chromebook 14-ca061dx Display Replacement: passo 4, imagem 2 %32
    • Use spudger or the iFixit opening tool to remove the bezel.
    • When prying, be careful not to damage or snap bezel. This is made up of very, thin plastic.
    • Pull bezel from the bottom, once all clips are detached.
    • Remove bezel.
  5. HP Chromebook 14-ca061dx Display Replacement: passo 5, imagem 1 %32 HP Chromebook 14-ca061dx Display Replacement: passo 5, imagem 2 %32
    • Remove the four 2mm JIS #000 screws.
  6. HP Chromebook 14-ca061dx Display Replacement: passo 6, imagem 1 %32 HP Chromebook 14-ca061dx Display Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
    • Be cautious when pulling back the tape—the connector/ribbon is fragile and could snap easily.
  7. HP Chromebook 14-ca061dx Display Replacement: passo 7, imagem 1 %32
    • Remove the LCD/display panel from the Chromebook frame.
Conclusão
Uma outra pessoa concluiu este guia.
Jean Arevalo
Membro desde: 10/31/19
778 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Membro de UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
Membros da 3
Autoria de 6 guias
Um comentário
should disconnect the laptop battery first
TJ Kleckner - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 2,663
