Ir para o conteúdo principal
HP Chromebook 14-ak041dx Motherboard Replacement
O que você precisa
  1. HP Chromebook 14-ak041dx Motherboard Replacement, Keyboard: passo 1, imagem 1 %32 HP Chromebook 14-ak041dx Motherboard Replacement, Keyboard: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
  2. HP Chromebook 14-ak041dx Motherboard Replacement: passo 2, imagem 1 %32 HP Chromebook 14-ak041dx Motherboard Replacement: passo 2, imagem 2 %32 HP Chromebook 14-ak041dx Motherboard Replacement: passo 2, imagem 3 %32
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
  3. HP Chromebook 14-ak041dx Motherboard Replacement: passo 3, imagem 1 %32 HP Chromebook 14-ak041dx Motherboard Replacement: passo 3, imagem 2 %32 HP Chromebook 14-ak041dx Motherboard Replacement: passo 3, imagem 3 %32
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
  4. HP Chromebook 14-ak041dx Motherboard Replacement, Battery: passo 4, imagem 1 %32 HP Chromebook 14-ak041dx Motherboard Replacement, Battery: passo 4, imagem 2 %32
    • Remove the four 3mm Phillips #000 screws holding the battery in place.
  5. HP Chromebook 14-ak041dx Motherboard Replacement: passo 5, imagem 1 %32 HP Chromebook 14-ak041dx Motherboard Replacement: passo 5, imagem 2 %32 HP Chromebook 14-ak041dx Motherboard Replacement: passo 5, imagem 3 %32
    Comprar
    • Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
    • Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
  6. HP Chromebook 14-ak041dx Motherboard Replacement: passo 6, imagem 1 %32
    • Carefully lift the battery out of the laptop.
  7. HP Chromebook 14-ak041dx Motherboard Replacement, Heat Sink: passo 7, imagem 1 %32 HP Chromebook 14-ak041dx Motherboard Replacement, Heat Sink: passo 7, imagem 2 %32 HP Chromebook 14-ak041dx Motherboard Replacement, Heat Sink: passo 7, imagem 3 %32
    • Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
    • Remove the heat sink from the laptop.
  8. HP Chromebook 14-ak041dx Motherboard Replacement, Wireless Card: passo 8, imagem 1 %32 HP Chromebook 14-ak041dx Motherboard Replacement, Wireless Card: passo 8, imagem 2 %32
    • Remove the single 2.5mm Phillips #00 screw from the wireless card.
    • Gently pull the wireless card from the motherboard to remove it.
  9. HP Chromebook 14-ak041dx Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 HP Chromebook 14-ak041dx Motherboard Replacement, Motherboard: passo 9, imagem 2 %32 HP Chromebook 14-ak041dx Motherboard Replacement, Motherboard: passo 9, imagem 3 %32
    Comprar
    • Gently pull the wire connector with a pair of tweezers to free it from the motherboard.
    • Use a pair of tweezers to remove the black ribbon cable from its connector.
    • Use the tweezers to detach the wire connector from the bottom left corner of the motherboard.
  10. HP Chromebook 14-ak041dx Motherboard Replacement: passo 10, imagem 1 %32 HP Chromebook 14-ak041dx Motherboard Replacement: passo 10, imagem 2 %32 HP Chromebook 14-ak041dx Motherboard Replacement: passo 10, imagem 3 %32
    • Remove the four Phillips #000 screws holding the motherboard in place.
    • Remove the motherboard from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 311
