Ir para o conteúdo principal
HP Chromebook 14-ak041dx Battery Replacement
O que você precisa
  1. HP Chromebook 14-ak041dx Battery Replacement, Keyboard: passo 1, imagem 1 %32 HP Chromebook 14-ak041dx Battery Replacement, Keyboard: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
  2. HP Chromebook 14-ak041dx Battery Replacement: passo 2, imagem 1 %32 HP Chromebook 14-ak041dx Battery Replacement: passo 2, imagem 2 %32 HP Chromebook 14-ak041dx Battery Replacement: passo 2, imagem 3 %32
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
  3. HP Chromebook 14-ak041dx Battery Replacement: passo 3, imagem 1 %32 HP Chromebook 14-ak041dx Battery Replacement: passo 3, imagem 2 %32 HP Chromebook 14-ak041dx Battery Replacement: passo 3, imagem 3 %32
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
  4. HP Chromebook 14-ak041dx Battery Replacement, Battery: passo 4, imagem 1 %32 HP Chromebook 14-ak041dx Battery Replacement, Battery: passo 4, imagem 2 %32
    • Remove the four 3mm Phillips #000 screws holding the battery in place.
  5. HP Chromebook 14-ak041dx Battery Replacement: passo 5, imagem 1 %32 HP Chromebook 14-ak041dx Battery Replacement: passo 5, imagem 2 %32 HP Chromebook 14-ak041dx Battery Replacement: passo 5, imagem 3 %32
    Comprar
    • Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
    • Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
  6. HP Chromebook 14-ak041dx Battery Replacement: passo 6, imagem 1 %32
    • Carefully lift the battery out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 512
