Ir para o conteúdo principal
HP Chromebook 14-ak013dx Internal Speaker Replacement
O que você precisa
  1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: passo 1, imagem 1 %32 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: passo 1, imagem 2 %32 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: passo 1, imagem 3 %32
    • Starting with the laptop on its back, remove the 13 screws holding the keyboard in place with a P00 screwdriver (2 screws are hidden behind the rubber footers)
    • Open the screen, revealing the keyboard. Using a prying tool, 'pop' the keyboard out by sliding the tool around the edge
  2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: passo 2, imagem 1 %32 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: passo 2, imagem 2 %32 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: passo 2, imagem 3 %32
    • Gently raise the keyboard from the body, careful not to rip out the ribbons
    • With light pressure, flip the black bar holding the ribbons in place, and remove the ribbons from the body
  3. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Keyboard: passo 3, imagem 1 %32
    • Completely remove the keyboard, place away from the body of the laptop
  4. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: passo 4, imagem 1 %32 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: passo 4, imagem 2 %32 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: passo 4, imagem 3 %32
    • With a P00 Screwdriver, remove the 9 screws holding the battery in place
    • Gently pry the cable connecting the battery to the motherboard off
    • Battery will lift away from the body (screen will now be heavier than the body, be careful not to drop it)
  5. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: passo 5, imagem 1 %32 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: passo 5, imagem 2 %32
    • Gently disconnect the cable connecting the internal speaker to the motherboard
    • Using a P00 Screwdriver, remove the final screw from the left speaker
    • Using a prying tool, carefully remove the speaker out of the body
  6. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: passo 6, imagem 1 %32 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: passo 6, imagem 2 %32
    • With a P00 Screwdriver, remove the final screw from the right speaker
    • Carefully remove the right internal speaker from the body
    • The entire speaker (barring some tape you may need to remove) should lift away from the body of the laptop
Conclusão
Uma outra pessoa concluiu este guia.
Cameron C Blanchard
Membro desde: 09/16/20
524 Reputação
Autoria de 4 guias
Equipe
dwsad Membro de dwsad
Community
1 Membro
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 87
