Introdução
When considering a screen replacement it is important to ensure that it is not a connection issue first. Once you determine that you have a tight fitting connection, if the display issues persist then you will need to replace the screen. Fortunately, this is a straight forward process with no special requirements or hazards.
O que você precisa
Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
