Introdução
After following previous guides as preliminary steps to removing the battery, you should be able to locate the battery and begin disassembly. Make sure to keep the battery screws seperate from others as they unique.
O que você precisa
Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
