Ir para o conteúdo principal
HP Chromebook 14-Q070NR Battery Replacement
O que você precisa
  1. HP Chromebook 14-Q070NR Battery Replacement, Keyboard: passo 1, imagem 1 %32
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Battery Replacement: passo 2, imagem 1 %32 HP Chromebook 14-Q070NR Battery Replacement: passo 2, imagem 2 %32 HP Chromebook 14-Q070NR Battery Replacement: passo 2, imagem 3 %32
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Battery Replacement: passo 3, imagem 1 %32 HP Chromebook 14-Q070NR Battery Replacement: passo 3, imagem 2 %32 HP Chromebook 14-Q070NR Battery Replacement: passo 3, imagem 3 %32
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Battery Replacement: passo 4, imagem 1 %32 HP Chromebook 14-Q070NR Battery Replacement: passo 4, imagem 2 %32 HP Chromebook 14-Q070NR Battery Replacement: passo 4, imagem 3 %32
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Battery Replacement, Battery: passo 5, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
    • Once removed, separate the screws from previous ones. They are different!
  6. HP Chromebook 14-Q070NR Battery Replacement: passo 6, imagem 1 %32 HP Chromebook 14-Q070NR Battery Replacement: passo 6, imagem 2 %32
    • Remove the taped flat wire from the top of the battery.
    • Carefully pull away the connector from the top of the battery to the motherboard.
  7. HP Chromebook 14-Q070NR Battery Replacement: passo 7, imagem 1 %32
    • Carefully lift the battery and remove it from the device.
Conclusão
Andres Martinez
Membro desde: 10/02/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S9-G5, Remmell Fall 2017 Membro de USF Tampa, Team S9-G5, Remmell Fall 2017
USFT-REMMELL-F17S9G5
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 411
