Ir para o conteúdo principal
HP Chromebook 14 G5 SD card reader Replacement
O que você precisa
  1. HP Chromebook 14 G5 SD card reader Replacement, SD card reader: passo 1, imagem 1 %32
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 SD card reader Replacement: passo 2, imagem 1 %32
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 SD card reader Replacement: passo 3, imagem 1 %32
    • Now we can see the SD card reader (in the yellow rectangle) that we need to tear down.
  4. HP Chromebook 14 G5 SD card reader Replacement: passo 4, imagem 1 %32
    • Remove the three 2mm screws around the SD card reader using the Phillips #00 Screwdriver.
  5. HP Chromebook 14 G5 SD card reader Replacement: passo 5, imagem 1 %32 HP Chromebook 14 G5 SD card reader Replacement: passo 5, imagem 2 %32
    • Disconnect the Flexible Flat Cable (FFC) from the motherboard.
  6. HP Chromebook 14 G5 SD card reader Replacement: passo 6, imagem 1 %32
    • Remove the SD card reader the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 314
