Ir para o conteúdo principal
HP Chromebook 11A G8 EE Wi-Fi Card Replacement
O que você precisa
  1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: passo 1, imagem 1 %32 HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: passo 1, imagem 2 %32
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 2, imagem 1 %32 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 2, imagem 2 %32 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 3, imagem 1 %32 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 3, imagem 2 %32
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Wi-Fi Card: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using your tweezers, unplug the battery connector from the motherboard.
  5. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 5, imagem 1 %32 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 5, imagem 2 %32 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 5, imagem 3 %32
    • Using your tweezers, peel back the clear sheet covering the Wi-Fi card.
    • Using a Phillips #0 screwdriver, remove the screw securing the Wi-Fi card cover.
    • Using your tweezers, remove the cover.
  6. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 6, imagem 1 %32 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: passo 6, imagem 2 %32
    • Using your tweezers, unsnap the the coaxial antenna cables from the Wi-Fi Card.
    • Slide the Wi-Fi card out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 40
Duração total: 750
