Ir para o conteúdo principal
HP Chromebook 11A G8 EE Screen Replacement
O que você precisa
  1. HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: passo 1, imagem 1 %32 HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: passo 1, imagem 2 %32
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Screen Replacement: passo 2, imagem 1 %32 HP Chromebook 11A G8 EE Screen Replacement: passo 2, imagem 2 %32 HP Chromebook 11A G8 EE Screen Replacement: passo 2, imagem 3 %32
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Screen Replacement: passo 3, imagem 1 %32 HP Chromebook 11A G8 EE Screen Replacement: passo 3, imagem 2 %32
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Screen Replacement, Bezel: passo 4, imagem 1 %32
    • Pry the hinge cap off with your hands by lifting it up.
  5. HP Chromebook 11A G8 EE Screen Replacement: passo 5, imagem 1 %32
    • Use the iFixit opening tool to pry the bezel up.
  6. HP Chromebook 11A G8 EE Screen Replacement: passo 6, imagem 1 %32
    • Once you have pried away the bezel, pull it up towards you.
    • Peel it off gently from the screen.
  7. HP Chromebook 11A G8 EE Screen Replacement: passo 7, imagem 1 %32
    • You are finished once the bezel is off of the device.
  8. HP Chromebook 11A G8 EE Screen Replacement, Screen: passo 8, imagem 1 %32
    • Remove the four 3.5 mm screws with the Phillips #0 screwdriver.
  9. HP Chromebook 11A G8 EE Screen Replacement: passo 9, imagem 1 %32
    • Flip the screen towards you.
  10. HP Chromebook 11A G8 EE Screen Replacement: passo 10, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Once the screen is flipped down, use the tweezers to peel away the black tape holding down the connector.
  11. HP Chromebook 11A G8 EE Screen Replacement: passo 11, imagem 1 %32
    • Next, peel away the tan tape, using the tweezers, exposing the screen connector.
  12. HP Chromebook 11A G8 EE Screen Replacement: passo 12, imagem 1 %32
    • Using the tweezers, remove the connector by the latch attached to it.
  13. HP Chromebook 11A G8 EE Screen Replacement: passo 13, imagem 1 %32
    • Finally, pull away the screen, to remove it from the device.
Conclusão
8 outras pessoas executaram este guia.
Kim Travers
Membro desde: 09/03/21
523 Reputação
Autoria de 2 guias
Um comentário
Does IFixit Sell this screen? I am unable to source parts and this screen for these educational units by HP. I wish iFixit would also list the parts that are needed for the repairs and not just the tools they sell.
Glenn Silva - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 57
Duração total: 3,207
