Ir para o conteúdo principal
HP Chromebook 11A G8 EE Keyboard Assembly Replacement
O que você precisa
  1. HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: passo 1, imagem 1 %32 HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: passo 1, imagem 2 %32
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 2, imagem 1 %32 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 2, imagem 2 %32 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 2, imagem 3 %32
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 3, imagem 1 %32 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 3, imagem 2 %32
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
Conclusão
6 outras pessoas executaram este guia.
Ella Portwood
Membro desde: 09/03/21
684 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 48
Duração total: 2,514
