Introdução
Sometimes the battery on the HP Chromebook 11-v011dx can malfunction and will need to be replaced. This guide will help you remove the battery.
O que você precisa
Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
Lift up the black rubber cap until it is completely removed.
Repeat this until all four of the black rubber caps are removed.
Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
Lift up the small black rubber cap until it is completely off.
Repeat this step one more time to remove the other small black rubber cap on the other side.
Remove three of the 1.3mm screws that keep the battery in place with a Phillips #0 screwdriver.
