Introdução
Use this guide to replace the speakers inside of the HP Chromebook 11-v002dx.
The speakers of your laptop can be damaged easily by liquids getting into the laptop through the speaker holes, or mechanical shock to the laptop itself.
Indication of failing speakers include muffled or no sound, ranges of sounds not being produced, or a constant output tone.
O que você precisa
Place your laptop bottom up on your work space.
Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
Flip up the black tab on the far right of the wire ribbon.
Gently pull the wire out of the black holder on its right, then out of the left side as well.
