Ir para o conteúdo principal
HP Chromebook 11 G8 EE Wi-Fi Card Replacement
O que você precisa
  1. HP Chromebook 11 G8 EE Wi-Fi Card Replacement, Keyboard & Touchpad Assembly: passo 1, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 2, imagem 1 %32 HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 3, imagem 1 %32 HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 3, imagem 2 %32 HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Wi-Fi Card Replacement, Wi-Fi Card: passo 4, imagem 1 %32
    Comprar
    • Use tweezers to unplug the battery connector from the motherboard.
  5. HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 5, imagem 1 %32
    • Peel back clear sheet covering Wi-Fi card.
    • Unscrew the single screw securing Wi-Fi card/cover using a Phillips #1 screwdriver.
    • Carefully slide the Wi-Fi card out.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
Membros da 5
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 54
Duração total: 509
