Introdução
If you are experiencing poor audio quality, first check the device's troubleshooting page. Then if you determine that the speaker's malfunction is a problem with the hardware, this guide is for you. A guide on how to replace your HP Chromebook 11 G8 EE's speakers. Before beginning this process make sure to power off your device and remove disconnect it from its charger.
O que você precisa
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Peel back the film over the speaker's motherboard connector.
Disconnect the speaker cable from the connector on the motherboard.
