Introdução
For this guide, you will be replacing the screen on your HP Chromebook 11 G8 EE. You may need to replace the screen if it is cracked or no longer functional. It's important your device is fully powered down throughout this process.
O que você precisa
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Quase terminado!
Conclusão
