Ir para o conteúdo principal
HP Chromebook 11 G8 EE Motherboard Replacement
O que você precisa
  1. HP Chromebook 11 G8 EE Motherboard Replacement, Keyboard & Touchpad Assembly: passo 1, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Motherboard Replacement: passo 2, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 2, imagem 2 %32
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Motherboard Replacement: passo 3, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 3, imagem 2 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Motherboard Replacement, Speaker: passo 4, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement, Speaker: passo 4, imagem 2 %32
    • Peel back the film over the speaker's motherboard connector.
    • Disconnect the speaker cable from the connector on the motherboard.
  5. HP Chromebook 11 G8 EE Motherboard Replacement: passo 5, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 5, imagem 2 %32
    • Unseat the speaker cable from the routing channel of the battery.
  6. HP Chromebook 11 G8 EE Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the four 3.5 mm screws from the base enclosure with a Phillips #1 screwdriver.
  7. HP Chromebook 11 G8 EE Motherboard Replacement: passo 7, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 7, imagem 2 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 7, imagem 3 %32
    • Lift the speakers off the base alignment pins to remove.
  8. HP Chromebook 11 G8 EE Motherboard Replacement, Battery: passo 8, imagem 1 %32
    • Do not puncture or damage any parts of the battery.
    • Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
    • The speakers are removed in these images, but they don't need to be to replace the battery.
  9. HP Chromebook 11 G8 EE Motherboard Replacement: passo 9, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 9, imagem 2 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 9, imagem 3 %32
    • Remove the four 3.5 mm Phillips #1 screws securing the battery.
    • If you've already removed the speakers, you'll only need to remove the two screws on the top of the battery, near the motherboard.
  10. HP Chromebook 11 G8 EE Motherboard Replacement: passo 10, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 10, imagem 2 %32
    • Carefully lift the battery up and out.
  11. HP Chromebook 11 G8 EE Motherboard Replacement, Motherboard: passo 11, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement, Motherboard: passo 11, imagem 2 %32 HP Chromebook 11 G8 EE Motherboard Replacement, Motherboard: passo 11, imagem 3 %32
    Comprar
    • Unscrew the single screw securing the Wi-Fi card/cover using a Phillips #1 screwdriver.
    • Remove wireless antenna cables from the module using tweezers.
    • Pull the Wi-Fi card out from its motherboard port using tweezers.
  12. HP Chromebook 11 G8 EE Motherboard Replacement: passo 12, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 12, imagem 2 %32
    • Disconnect the webcam cable from the motherboard using tweezers.
  13. HP Chromebook 11 G8 EE Motherboard Replacement: passo 13, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 13, imagem 2 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 13, imagem 3 %32
    • Flip the two black lock bars on the ZIF connectors using tweezers.
    • Disconnect both ribbon cables from the motherboard using the tweezers.
  14. HP Chromebook 11 G8 EE Motherboard Replacement: passo 14, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 14, imagem 2 %32
    • Disconnect the power cable from the I/O board using tweezers.
  15. HP Chromebook 11 G8 EE Motherboard Replacement: passo 15, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 15, imagem 2 %32
    • Peel back the film and lift the lock bar on the display panel cable with tweezers.
    • Disconnect the display panel connector with tweezers.
  16. HP Chromebook 11 G8 EE Motherboard Replacement: passo 16, imagem 1 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 16, imagem 2 %32 HP Chromebook 11 G8 EE Motherboard Replacement: passo 16, imagem 3 %32
    • Remove the six 3.5 mm screws with a Phillips #1 screwdriver.
    • Lift the USB-C bracket off the motherboard.
  17. HP Chromebook 11 G8 EE Motherboard Replacement: passo 17, imagem 1 %32
    • Lift the motherboard up and out.
Conclusão
Philip Pedersen
Membro desde: 10/25/22
207 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
Membros da 5
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 659
