Ir para o conteúdo principal
HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement
O que você precisa
  1. HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement, Keyboard & Touchpad Assembly: passo 1, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: passo 2, imagem 1 %32 HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: passo 2, imagem 2 %32
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: passo 3, imagem 1 %32 HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: passo 3, imagem 2 %32 HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
Conclusão
Julia Latura
Membro desde: 10/25/22
328 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
Membros da 5
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 35
Duração total: 646
