Ir para o conteúdo principal
HP Chromebook 11 G8 EE Bezel Replacement
O que você precisa
  1. HP Chromebook 11 G8 EE Bezel Replacement, Keyboard & Touchpad Assembly: passo 1, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Bezel Replacement: passo 2, imagem 1 %32 HP Chromebook 11 G8 EE Bezel Replacement: passo 2, imagem 2 %32
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Bezel Replacement: passo 3, imagem 1 %32 HP Chromebook 11 G8 EE Bezel Replacement: passo 3, imagem 2 %32 HP Chromebook 11 G8 EE Bezel Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Bezel Replacement, Bezel: passo 4, imagem 1 %32 HP Chromebook 11 G8 EE Bezel Replacement, Bezel: passo 4, imagem 2 %32
    • Using your hands, pry off the hinge cover by lifting it.
  5. HP Chromebook 11 G8 EE Bezel Replacement: passo 5, imagem 1 %32 HP Chromebook 11 G8 EE Bezel Replacement: passo 5, imagem 2 %32 HP Chromebook 11 G8 EE Bezel Replacement: passo 5, imagem 3 %32
    • Using the opening tool, pry the bezel away from the top case.
    • It requires a bit of force; you aren't going to break it!
  6. HP Chromebook 11 G8 EE Bezel Replacement: passo 6, imagem 1 %32
    • Pull the bezel toward you.
    • Peel it away from the screen gently.
  7. HP Chromebook 11 G8 EE Bezel Replacement: passo 7, imagem 1 %32
    • Completely remove the bezel.
Conclusão
Uma outra pessoa concluiu este guia.
Isabella Brown
Membro desde: 10/25/22
312 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
Membros da 5
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 38
Duração total: 352
