Ir para o conteúdo principal
HP Chromebook 11 G8 EE Battery Replacement
O que você precisa
  1. HP Chromebook 11 G8 EE Battery Replacement, Keyboard & Touchpad Assembly: passo 1, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Battery Replacement: passo 2, imagem 1 %32 HP Chromebook 11 G8 EE Battery Replacement: passo 2, imagem 2 %32
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Battery Replacement: passo 3, imagem 1 %32 HP Chromebook 11 G8 EE Battery Replacement: passo 3, imagem 2 %32 HP Chromebook 11 G8 EE Battery Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Battery Replacement, Battery: passo 4, imagem 1 %32
    • Do not puncture or damage any parts of the battery.
    • Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
    • The speakers are removed in these images, but they don't need to be to replace the battery.
  5. HP Chromebook 11 G8 EE Battery Replacement: passo 5, imagem 1 %32 HP Chromebook 11 G8 EE Battery Replacement: passo 5, imagem 2 %32 HP Chromebook 11 G8 EE Battery Replacement: passo 5, imagem 3 %32
    • Remove the four 3.5 mm Phillips #1 screws securing the battery.
    • If you've already removed the speakers, you'll only need to remove the two screws on the top of the battery, near the motherboard.
  6. HP Chromebook 11 G8 EE Battery Replacement: passo 6, imagem 1 %32 HP Chromebook 11 G8 EE Battery Replacement: passo 6, imagem 2 %32
    • Carefully lift the battery up and out.
Conclusão
Julia Latura
Membro desde: 10/25/22
328 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
Membros da 5
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 54
Duração total: 820
