Ir para o conteúdo principal
HP Chromebook 11 G5 Keyboard Replacement
O que você precisa
  1. HP Chromebook 11 G5 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 Keyboard Replacement: passo 4, imagem 1 %32
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 Keyboard Replacement: passo 5, imagem 1 %32
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 Keyboard Replacement: passo 6, imagem 1 %32
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 Keyboard Replacement: passo 7, imagem 1 %32
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 Keyboard Replacement: passo 8, imagem 1 %32
    • Gently remove the keyboard assembly by hand from the base of the device.
Conclusão
4 outras pessoas executaram este guia.
Salma Zitoun
Membro desde: 01/14/20
385 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 943
