Introdução
This is a replacement guide for the HP Chromebook 11 G5 keyboard. The main purpose of the steps below is to show you how to replace the keyboard. The keyboard is required to input characters and perform various manual functions. Symptoms of a defective keyboard include unresponsive or broken keys. If these steps are followed carefully and correctly the keyboard should be easily replaced. Be sure to power off your device before beginning the replacement process.
O que você precisa
Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
4 outras pessoas executaram este guia.
