Ir para o conteúdo principal
HP Chromebook 11 G4 Wi-Fi Card Replacement
O que você precisa
  1. HP Chromebook 11 G4 Wi-Fi Card Replacement, Keyboard: passo 1, imagem 1 %32
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 2, imagem 1 %32 HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 3, imagem 1 %32 HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 3, imagem 2 %32
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 4, imagem 1 %32
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 5, imagem 1 %32 HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 6, imagem 1 %32
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 7, imagem 1 %32 HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 7, imagem 2 %32 HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 7, imagem 3 %32
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 8, imagem 1 %32
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 Wi-Fi Card Replacement, Wi-Fi Card: passo 9, imagem 1 %32
    • Remove the 4 mm Phillips #1 screw.
  10. HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 10, imagem 1 %32 HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 10, imagem 2 %32
    • Gently slide out the Wi-Fi card away from the motherboard by gripping the edges with your thumb and index finger.
  11. HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 11, imagem 1 %32 HP Chromebook 11 G4 Wi-Fi Card Replacement: passo 11, imagem 2 %32
    • Pop off the white and black wires.
    • The white and black wires have numbered tags on them. These numbers correspond to the numbers on the connection point of the Wi-Fi Card.
Conclusão
Uma outra pessoa concluiu este guia.
Jair Herrera
Membro desde: 04/26/17
694 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S16-G5, Banghart Winter 2018 Membro de Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
Membros da 5
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 1,791
