Introdução
This guide will walk you through the replacement process of a defective or broken keyboard on your HP Chromebook 11 G4. Removing the keyboard is also the basic step to accessing all of the other internal components.
O que você precisa
3 outras pessoas executaram este guia.
3 comentários
Same question as the person above. I need to remove the keyboard from the assembly.
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
