Ir para o conteúdo principal
HP Chromebook 11 G3 Touchpad Replacement
O que você precisa
  1. HP Chromebook 11 G3 Touchpad Replacement, Keyboard Mount: passo 1, imagem 1 %32 HP Chromebook 11 G3 Touchpad Replacement, Keyboard Mount: passo 1, imagem 2 %32
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Touchpad Replacement: passo 2, imagem 1 %32 HP Chromebook 11 G3 Touchpad Replacement: passo 2, imagem 2 %32
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Touchpad Replacement: passo 3, imagem 1 %32
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Touchpad Replacement: passo 4, imagem 1 %32 HP Chromebook 11 G3 Touchpad Replacement: passo 4, imagem 2 %32 HP Chromebook 11 G3 Touchpad Replacement: passo 4, imagem 3 %32
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Touchpad Replacement: passo 5, imagem 1 %32
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Touchpad Replacement, Touchpad: passo 6, imagem 1 %32 HP Chromebook 11 G3 Touchpad Replacement, Touchpad: passo 6, imagem 2 %32 HP Chromebook 11 G3 Touchpad Replacement, Touchpad: passo 6, imagem 3 %32
    • Flip the keyboard mount upside down.
    • Use tweezers to lift the tape on the bottom of the touchpad to expose the connector.
    • With a spudger, push up the ZIF retaining flip.
    • Pull out the small ribbon cable.
  7. HP Chromebook 11 G3 Touchpad Replacement: passo 7, imagem 1 %32 HP Chromebook 11 G3 Touchpad Replacement: passo 7, imagem 2 %32
    • Remove the two Phillips #00 2mm screws that secure the touchpad to the black plastic housing.
    • Flip the keyboard mount to the upright position.
    • From beneath, push the touchpad up through the top of the keyboard mount to remove it.
Conclusão
Rahul Goyal
Membro desde: 04/26/17
1.369 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team S23-G3, Livingston Spring 2017 Membro de Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 1,330
