Ir para o conteúdo principal
HP Chromebook 11 G3 Keyboard Replacement
O que você precisa
  1. HP Chromebook 11 G3 Keyboard Replacement, Keyboard Mount: passo 1, imagem 1 %32 HP Chromebook 11 G3 Keyboard Replacement, Keyboard Mount: passo 1, imagem 2 %32
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Keyboard Replacement: passo 2, imagem 1 %32 HP Chromebook 11 G3 Keyboard Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Keyboard Replacement: passo 3, imagem 1 %32
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Keyboard Replacement: passo 4, imagem 1 %32 HP Chromebook 11 G3 Keyboard Replacement: passo 4, imagem 2 %32 HP Chromebook 11 G3 Keyboard Replacement: passo 4, imagem 3 %32
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Keyboard Replacement: passo 5, imagem 1 %32
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32 HP Chromebook 11 G3 Keyboard Replacement, Keyboard: passo 6, imagem 2 %32
    Comprar
    • Flip the keyboard mount upside-down.
    • Using tweezers, peel off the two pieces of copper tape that keep the keyboard’s metal cover attached to the keyboard mount.
  7. HP Chromebook 11 G3 Keyboard Replacement: passo 7, imagem 1 %32
    • Using tweezers, pull back the three metallic-colored pieces of tape near the top left corner of the keyboard mount.
  8. HP Chromebook 11 G3 Keyboard Replacement: passo 8, imagem 1 %32 HP Chromebook 11 G3 Keyboard Replacement: passo 8, imagem 2 %32
    • Remove the two 4 mm Phillips #00 screws located on either side of the horizontal black fastener located directly above the touchpad.
    • Lift the horizontal black fastener.
  9. HP Chromebook 11 G3 Keyboard Replacement: passo 9, imagem 1 %32 HP Chromebook 11 G3 Keyboard Replacement: passo 9, imagem 2 %32 HP Chromebook 11 G3 Keyboard Replacement: passo 9, imagem 3 %32
    • Use a plastic opening tool to pry the edges of the metal cover.
    • Loosen the adhesive around the perimeter of the metal cover.
    • The adhesive can be difficult to remove. Use tweezers on any troubling sections. After removing the adhesive, take off the keyboard’s metal cover.
    • If the cover doesn’t come off, repeat prying around the edges with a plastic opening tool.
    • Lift the metal cover.
    • Apply adhesive during reassembly to fasten the metal cover onto the keyboard mount.
    • If only certain keys need replacement, stop here. Instead, use tweezers to remove individual keys by loosening their four snap-on clips from the metal backing.
  10. HP Chromebook 11 G3 Keyboard Replacement: passo 10, imagem 1 %32 HP Chromebook 11 G3 Keyboard Replacement: passo 10, imagem 2 %32
    • Use a plastic opening tool to disconnect the keyboard from the keyboard mount by prying along the keyboard’s perimeter.
    • Lots of adhesive attaches the keyboard to the keyboard mount. Loud snapping noises and gray, circular plastic debris are common during adhesive removal.
    • After removing enough adhesive, remove the keyboard’s backing.
    • Apply adhesive during reassembly to fasten the keyboard and its metal backing onto the keyboard mount.
Conclusão
Rahul Goyal
Membro desde: 04/26/17
1.369 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team S23-G3, Livingston Spring 2017 Membro de Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
Membros da 4
Autoria de 12 guias
Um comentário
Is it possible to get a keyboard that lights up for the HP Chromebook 11 G3? If so then how?
Vanessa Nations - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 2,166
