Introdução
This guide walks through replacing a faulty battery. It requires removing the keyboard mount. Afterwards, it is relatively simple and requires only a Phillips head screwdriver to finish removal.
O que você precisa
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Gently remove the battery’s rainbow-colored bundled cable from the motherboard.
5 outras pessoas executaram este guia.
Um comentário
Can the HP Chromebook 11 G3 be operated from the power adapter after the battery has been removed?
