Introdução
This guide describes how to replace a faulty motherboard in an HP Chromebook 14-x013dx. A malfunctioning motherboard could be due to overheating or other damage to the laptop. This replacement involves removing the laptop’s keyboard, and the total repair time should take about 25 minutes.
O que você precisa
Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
Uma outra pessoa concluiu este guia.
