Ir para o conteúdo principal
HP Beats Special Edition 15-p390nr Speakers Replacement
O que você precisa
  1. HP Beats Special Edition 15-p390nr Speakers Replacement, Keyboard: passo 1, imagem 1 %32 HP Beats Special Edition 15-p390nr Speakers Replacement, Keyboard: passo 1, imagem 2 %32
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Speakers Replacement: passo 2, imagem 1 %32 HP Beats Special Edition 15-p390nr Speakers Replacement: passo 2, imagem 2 %32
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Speakers Replacement: passo 3, imagem 1 %32 HP Beats Special Edition 15-p390nr Speakers Replacement: passo 3, imagem 2 %32
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Speakers Replacement: passo 4, imagem 1 %32 HP Beats Special Edition 15-p390nr Speakers Replacement: passo 4, imagem 2 %32
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Speakers Replacement: passo 5, imagem 1 %32 HP Beats Special Edition 15-p390nr Speakers Replacement: passo 5, imagem 2 %32
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Speakers Replacement: passo 6, imagem 1 %32 HP Beats Special Edition 15-p390nr Speakers Replacement: passo 6, imagem 2 %32
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr Speakers Replacement, Motherboard: passo 7, imagem 1 %32
    • Remove screws from the motherboard.
    • 11 screws should be removed from the motherboard
  8. HP Beats Special Edition 15-p390nr Speakers Replacement: passo 8, imagem 1 %32
    • Unclamp wire strips from motherboard.
  9. HP Beats Special Edition 15-p390nr Speakers Replacement: passo 9, imagem 1 %32
    • Detach by lifting the motherboard up and flip the motherboard over.
  10. HP Beats Special Edition 15-p390nr Speakers Replacement: passo 10, imagem 1 %32
    • Unclip wifi card for further procedures
  11. HP Beats Special Edition 15-p390nr Speakers Replacement, Speakers: passo 11, imagem 1 %32
    • Remove the screws from the hinge on each side
  12. HP Beats Special Edition 15-p390nr Speakers Replacement: passo 12, imagem 1 %32
    • Remove the speakers
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 711
