Ir para o conteúdo principal
HP 8 1401 Rear-Facing Camera Replacement
O que você precisa
  1. HP 8 1401 Rear-Facing Camera Replacement, Back Panel: passo 1, imagem 1 %32
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Rear-Facing Camera Replacement: passo 2, imagem 1 %32
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Rear-Facing Camera Replacement: passo 3, imagem 1 %32 HP 8 1401 Rear-Facing Camera Replacement: passo 3, imagem 2 %32
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Rear-Facing Camera Replacement, Rear-Facing Camera: passo 4, imagem 1 %32 HP 8 1401 Rear-Facing Camera Replacement, Rear-Facing Camera: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
    • Lift the rear-facing camera out of its compartment using the tweezers.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 133
