Introdução
This guide can help if your power or volume buttons are broken. The power/ volume board may not be completely attached to the control board so be careful when unhooking the clip.
O que você precisa
Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
Disconnect the power/ volume button board from the control board by pulling the ribbon cable out of the white connector. You can use tweezers or your fingers.
Quase terminado!
Conclusão
