Ir para o conteúdo principal
HP 8 1401 Back Panel Replacement
O que você precisa
  1. HP 8 1401 Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Back Panel Replacement: passo 2, imagem 1 %32
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Back Panel Replacement: passo 3, imagem 1 %32 HP 8 1401 Back Panel Replacement: passo 3, imagem 2 %32
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
Conclusão
To reassemble your device, follow these instructions in reverse order. Align the front and back panels and press them together, then screw in the four screws.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 340
